cobra 2000 meters
blackjack said:
anybody know were to get some meters for the 2000gtl. mine are broken and would like to replace them. thanks
Are you sure they are broken? Mine were only stuck. If you take them out there is a screw on the back that controls the pivot of the meter movement. I put a little silicone on the pivots and turned the screw to loosen up the movement. That fixed mine. Counterclockwise seemed to loosen and clockwise tightened.
