Cobra 25LTD Classic
Smokinone
WDX-3820
Jun 24, 2020
1,015
1,361
173
Southern Nevada
Working on a 25 LTD Classic for my nephews truck. It's an older Taiwan model that has been sitting in the garage for years, his, not mine. I didn't get a pic but the speaker side of the cover had all the wax and stuff on one side that had leaked from the board. No big deal, cleaned up nicely after a little heat gun action.
Preliminary check out, it did power up and receive, also keyed up and showed about 4 watts output. I then began the re-cap process. I took readings of the caps on the way out and made a poor looking chart of values, excuse the handwriting. I didn't record the voltages but they were from 6.3V on up...a lot of 10V caps.
New silpads for the final and driver installed as well.
As you can see, even if the radio appears to be OK on the preliminary test, a lot of the caps were not within spec...some by a long shot.
I have cleaned the board both sides, component side and solder side. 25 caps replaced. Glued the face plate back on and cleaned it. Knobs are in solution to clean them, cleaned the back of the radio somewhat, wanted to keep a little of the accumulation of dirt for patina.
Moving on the the alignment stage after a little break:giggle:
After the re-cap
Niiiiiiiiice! The 1990s Cobras were ok. After that? No thank you. :)
I did recap a 25 GTL and an original 25 LTD. For whatever reason, the 25 GTL would do a "double click" of the relay on ol RM-Italy 203P every time you would key up... The 25 LTD worked fine and didn't do that. Something on the GTL AM only radios that would do that to the amp. I don't have it connected up now but maybe sometime get it connected and make a quick video on that and hope someone knows why that even happens.
This 25LTD Classic now showing 4.5 watts dead key, and swings to about 30watts according to my WM-1. Can that be right?
The Mectron I just re-capped swings to about 15 watts on the WM-1, it's probably a little earlier production than the Cobra.
I'm guessing the 25LTD Classic is maybe 1983 vintage as the first 2 numbers in the serial number are 83...just a guess, I can't really find anything on production dates.
Did you check it with a scope? Id venture a guess the limiter is clipped and you have some harmonics in there. It's a solid rig, is it the stock driver and final?
Edit, I see it's a stock 2078, so the 30 watts are definitely dirty.
Edit2, I see D9 is clipped. Restore that and adjust for 100% to see what your putting out clean. It should sound great with a good mic.
Good eye. I didn't see it till you brought it to my attention. Will get it back together and re test. Thanks much. Always great help on this forum, that's one of the reasons I'm here every day.
Reactions: Cable Guy
Thanks again, about 15 watts now with the repaired diode, good n clean audio
Reactions: doffo and Cable Guy
Good catch! I was about to look back at the pictures to see if something was clipped.
Could you tell me what component is the limiter in this radio? I think I still have some overmod as the scope shows a lot of what appears to be spiking.
Thanks
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
