Cobra 29 Channel Display Upgrade
if you know what you are doing it is fairly easy to do. there is 16 legs on the display to unsolder and resolder to get it changed plus it will only go in one way. if upside down it will not work. you also have to tear the front of the radio down to do this also.
If you ever try changing the display, be very carefull with the double sided board, dont get it too hot, very sensitive. Use a solder sucker from Ratshack & a very fine tip solder gun, dont forget about the rx/tx led too.
Reactions: LeapFrog
