putting a channel kit in a 29 ltd. why? cause its here and i have a kit for whatever reason. using these instructions... http://www.cbtricks.com/miscellaneous/v ... bra_29.htm . what would be a good source for 13.8 volts and what would be a good ground on the board. i was going to wire to the red wire on the on off switch and ground to chassis. yes? no? i would prefer a very simplified answer as im an idiot that can solder. explain it like you would explain it to a kindergarten kid. much abliged
