This is just the basic idea.
Credit should go to CBphreaker whos excellent work and kind mentorship brought these mods to light.
A.) Disconnect the 10.240MHz signal from the TX mixer. Build a 10.695MHz oscillator and inject this signal into the mixer instead.
Add a SPST switch (tied to ground) for the PLL T/R switch. We will be using one set of n-codes per band!
The TX n-code set will now get you a 40 channel band starting at 27.4100MHz or so, but channels will end on 27.xx0's and not 27.xx5's.
B.) Super-Slider VXCO Mod.
Disconnect the 5.12MHz signal going from the PLL to the tripler, build a 5MHz variable oscillator this signal will now go to the tripler instead. You can use a ten turn potentiometer to finely adjust the control voltage.
C.) Frequency Counter Mod.
For the PLJ-6LED, PLJ-8LED & Galaxy FC-347 counters to read during receive you must install the 10.695MHz oscillator. PLL will be using the receive set of n-codes in normal band. Sample your signal right at the mixer.
I haven't built this myself, but let us discuss
I failed to mention something, or explained incorrectly..
"Kintsugi"
-Leap
A.) The "Two Bands Mod".
{2 bands of 40 Channels using the stock "unmodifiable" PLL.}
B.) Super-Slider VXCO "extreme delta tune".
{Recommended to get to 27.xx5's when using the TX n-codes set of the Two Bands Mod.}
{Working for Transmit, & Receive!
Compatible with: PLJ-6LED PLJ-8LED, Galaxy FC-347 frequency counters & Lesscomm 3 band pcb's.}
"Kintsugi"
-Leap
