Damn ! I didn't catch that Freecell ! I don't think you meant what you said 100 . You DO NOT want to jumper that diode ! you want to remove it as we said , the power there is meant to go in one direction only , that's what the diodes for , if you jumped it , power would go the wrong way as well , then your looking for trouble , that's why the diode is there in the first place , this is why they put fuses in line with the power cords as well.
Protect diodes usely go because the radio was hooked up backwards without a fuse in line on the power cord or maybe there was to big of a rated fuse in line with the power cord when hooked up backwards ? this could also blow the diode. The fuse inline with the power cord and the diode in the radio are both to protect the radio from further damages and our investments. I believe the 29s run a 2 amp fuse in the power cord , you hook it up backwards , the fuse goes instead of the diode in the radio , you hook it up with much larger fuse rating backwards , the diode might go as well. You hook it up backwards without a fuse inline , diode goes bye bye. So in other words , it's a lot easier to change a fuse in the power line then it is to change the radios protect diode. You confused yet. (-:
