Connex 33 HP Max
Illahe
Jun 3, 2026
55
26
18
57
Anyone using one of the newer Connex options. I am looking for a frequency counter wiring harness that interphases with the jack on the back of this unit.
Does that mean you want the socket and wires that were attached inside the Galaxy radio from the factory?
If it is, I still have a couple of them left on fleabay: This package let you adapt the Galaxy display to a radio that lacked that socket on the rear.
https://www.ebay.com/itm/1169746545...pid=5336136228&customid=&toolid=10001&mkevt=1
And if you want the plug and wire found on the display, don't have that one.
The sockets/wires and brackets came with counters we sold back in the day. Those parts were left over if your radio had that socket already.
Does that mean you want the plug and wires that were attached to the Galaxy counter from the factory?
Thanks.
It appears the pin layout is the same. Though I only see 4 metal contacts in the 6 pin receptacle of the transceiver. I cant stomach the cost of a freq. counter after shelling (X) for the transceiver...
I will get a good look at the receptacle in the morning.
