CONNEX 4600 TURBO
rockenranger
Dec 17, 2011
104
3
53
I have a connex 4600 turbo the meter is off some ive looked on the net but cant find anything about adjustments. could someone tell what they are or where i could find them at thanks
What do you mean the meter is off some? Are you talking about "S" meter readings, or wattage readings? There is an alignment procedure for those but you need some equipment to do it. If it's wattage readings I would not even mess with it, those meters were never intended to give you anything more then a ballpark relative output indication. You will need an external watt meter for that.
