Don't forget that the average pre-amp is also going to amplify the noise level too. I would rather listen to a clean S3 signal than a pre-amped S6 with noise I couldn't hear before the amp was added.
I got a tristar 747 modded for a preamp. Have a search for 2sc2999 on this site to see how its done. I find the best way to know if a radio will improve from it is to listen to the clarity of the weakest signal out there on fully clockwise gain when skip is g0‹2ne. The more gain is added the worse the clarity will distort. If weak signals are already at the limit of intelligibility then it cannot be bettered. I had my 747 done because when i was hiltopping far away from any static i could hear low voices on ssb with the volume fully clockwise and still not get them loud enough to understand.
Consider replacing the transistors in the receive section with higher gain lower noise models. Do the front end diode swap for faster switching lower noise and increased sensitivity. Should not be that hard to find a mod for this online for another radio and just apply the same idea to your radio.
Also consider directional beam antenna if you are not already running one. Generally if you need a pre-amp to hear them then you will not be able to talk to them.The reason most amps have preamps is because the people you are talking to may not be running any where near the power you are running no point of being heard if you can not copy the other guy!
Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
