CR577 problem
buickid
304 'round the minigrass
Nov 22, 2012
242
149
53
Kona, Hawaii
Got a RF Limited CR577, which has been working great for me. Recently, it started acting strange. When I key the mic and apply a constant tone, the watt meter slowly rises to full output. Using the stock mic on the radio, the watts quickly jump to full output as expected. Once the output rises to full, as long as you don't release the key, it works as normal. I figure something must be on its way out on the little amplifier in the 577, perhaps a cap or something. A new fresh battery didn't change anything.
Anyone seen anything like this? Love the way this mic sounds.
-Trevor
Does it act up when you talk into the mic? It might not like the tone or signal input in your example.
Yeah even when talking. If I start counting up (ie. 1 2 3 4 5 6) as soon as I key, the first few numbers are soft, then increase in volume (confirmed over the air). Once it gets over that though, it works perfectly for the duration of that "key".
