D104 TUG8 & ICOM 718
Rudes
Dec 20, 2008
52
I wired up one of my D104 mics to my Icom-718 and I was surprised to see that it works WITHOUT a battery! How can that be? Also it performs well on SSB but on AM I can hear a squeal coming from inside the radio when keyed even if the mic element is removed from the mic base. I hooked a battery up and it changes nothing. Anyone know why there is a problem on AM with the mic base and how to correct it. Thanks in advance!
Until someone pipes in - take a look at TUP9 D104 to Icom 718.
TUG8
This particular one has the gain pot soldered to the board unlike my 2 other D104s that use an outboard pot.
Battery
Solved the problem. Seems that the battery I was using was too low. When I put a fresh battery in the squeal stopped. Sideband will work without a battery but not AM.
What stand is it? T-UG8, T-UG9 or T-UP9?
Dah..sorry, you had the stand type in the title. it was too early when I posted this morning...:sleep:
There is a way to run phantom power from the Icom mic jack (voltage is already present there) to the D-104 so you don't have to worry about a battery. I'll find the instructions when I get home
i have two mint minute man IIs.
i thought amplified mikes on a Ham radio was well pointless?
  • @ wavrider:
    sea que sea que,
