Delta Force problems?
  • Thread starter Thread starter Tumbleweed
  • Start date Start date
T
Tumbleweed
Guest
My DF is having problems with txing. It's been intermitent now it's doing it constatnly. When I key it's shows modulation on the bar graph but it's not. I hear a relay clicking, opened it up and it's the relay on the small board that's attached to the frame behind the channel selector when you take the bottom cover off. I'm not sure if it's the relay or some other problem that's making the relay click. I realize this is kind of vague, but has anyone else had this problem with the Delta Force?
Thanks,
CDX-350
2AK3350
</p>
Thanks,
CDX-350
2AK3350
</p>
Doesn't ring a bell T, but you can call Magnum. Their warranty repair tech is very good.
Wm. Warlock "71 and the long black limousine in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
</p>
Thanks RR, I'll give them a call.
After letting in set for a day unplugged, it's working again.
It's odd.
I seen that pic of the S9??? I believe that's the model? That's a nice looking Magnum, I'll have to get one of those.
CDX-350
2AK3350
</p>
It's odd.
CDX-350
2AK3350
</p>
Join the club...the Omega is finally supposed to materialize in the next six weeks, then the S9 in the next couple months. You can bet I'll be one of the first to own each.
</p>
</p>
