Dentron 2000A Q&A
Yankee
307
22
As you can see from these images, the inside, when I opened it, was clean and did not show any signs of arcing or smell of smoke or heat. But, I did not get a manual, although I do have a PDF copy.
My problem is, I can not get it to work consistantly. The question is, what can go wrong with these things that would make them not work correctly? Or do I have the wrong idea of what they are meant to do? [probably]
I seem to get the meter to show what the manual says it will show, but then I go to check SWR and it's sky high. that can't be right?
