Its at a 45° angle so it's kind of horizontal and kind of vertical.527, welcome to the forum.
Is the dipole vertical or horizontal?
I'm assuming it's center-fed; how high is the center and how high are the ends?
And you don't NEED to get it down to a 1:1 SWR. That in itself is often impossible given metallic objects in the near field, type of feedline, etc. As long as the power doesn't cut back (assuming again that the radio has such a feature built in), you're good to go.
Not if the antenna itself doesn't think soNo quite a 90 but temporary. Hearing 38lsb aprox 100miles out oddly. Im hearing North I should get East and West.
