I want to be able to key my President Lincoln independently of the mic circuit. I know it has a circuit available from the factory through he accessory plug for CW.
Does this only break the Continuous Wave on CW and transmit or will this effectively key the radio no matter what mode you are operating in.
I want to try using some external processing and non-rf commercial condensor mic's and the like. Initially I want to feed the processed audio into the mic jack. I do not want to modify anything that I do nto have too. It would be super convenient if I did not have to wire up sometime special just to test this out. Same thing with trying direct injection latter on it saves time and space if I do not need to drill more holes for phono jacks and the like.
Thanks guys
Thanks guys
