Dosy fc50 frequency counter noise issues
kaos513
Apr 10, 2014
2,391
734
123
47
Putnam county,NY
Hello I have a dosy fc50 frequency counter every time I turn it on some type of huming noice bleeds over to my base station when I turn it off it goes alway any help would be appreciated, by the way I changed the jumpers a couple of times already.Thanks
Did it do it before? What have you done different? A hum is usually a ground loop problem. Are all the components plugged into the same location?
Need more information from you.
Yes all equment is plug into a power strip has never done that before,also tried to relocate the power adapter from the frequency counter to a different outlet same results
