Drive around antennas
  • Thread starter Thread starter Bootlegger123
  • Start date Start date
B
Bootlegger123
Guest
anybody have any plans/ideas on a mobile beam,,i listed a post awhile back with no luck,so im gonna try again maybe this will spark a thought,,just looking for something to play with..
Bootlegger
</p>
Bootlegger
</p>
Here is a link to check out the 4 antenna set up.
www.comteksystems.com/
It is intended for base operation, but for 10/11 meters should work mobile.
I'm in the process of looking for some one to build a custom ladder rack (that's what I tell my accountant) with flat surfaces to accommodate the 4-square, the "Super Scanner" type antenna, and the half yagi type set up you most often see at keydowns. I hope I never have to carry a ladder.
I was going to give them all a try. I'm thinking the "Super Scanner" type will be the best all around antenna. The Yagi type will be best when parked on a hill top.
Let me know if you get any closer to trying one of them. I've been on the road almost 3 of the last 4 months so I haven't had a lot of spare time at home. But I made a lot of sketches sitting in the hotel.
There is a high geek factor with one of these antennas, but I use my radio addition to hide my stripper and alcohol addiction.
</p>
</p>
