Dual Band (6m/10m) helically wound antenna
tahrens
Jun 13, 2009
29
Hi Folks,
I'm trying to build a mobile dual band antenna for 6 & 10 meters.
I read an article back from a year ago in QST where the author
started with a full size CB whip, cut it half, and used a polycarbonite
coupler (with a trap built on it for 10m).
Sounded ok, but I neither had a CB whip, nor did I have a way to
make the coupler.
I did have one of those helically wound HF mobile antennas for 20m
that I could sacrifice to the project.
Got the base all wound & had an excellent match on the 6m FM
frequency that I wanted (had to add about 47pF to the base to
make it happy). Then I made the trap at the top of the whip
for 10m (with the whip attached to the top).
When I checked for the 10m resonance, I found it to be a little lower
than I needed, so I decided to pull a couple of turns from the trap.
Before I did that, I re-checked the 6m resonance point, and it had gone
up to 60mHz!
Anybody have a clue what's going on here, & why it jumped up?
Thanks,
Tim W5FN
My shot in the dark guess is that you should do the matching for 6m after you've got the trap set for 10m. Are you able to get a good match on both 10m and 6m if you change the capacitance at the base?
dual band antenna
Hi Mole,
I got a good match on 6 (without trap or top whip), but when I tried to add anything at the top, the resonant frequency went really wierd.
I'm getting a 'regular' whip to put on the spring tomorrow. I might play
with adding something to top with it. (more like the original plans spec'd).
I'll keep you posted.
Thanks!
Tim W5FN
