DX-959 Receiver Alignment Typo Error
4ZERO99
Jun 25, 2013
50
9
18
I'm not sure where to post this so here goes:
I can't seem to get a hold of anyone at cbtricks to find out it there is a typo on the receive alignment page for the DX-959 Receiver Alignment for the
LSB Sensitivity:
Set radio to CH 19 LSB mode.VOL control fully clockwise.RF SG setting to 27.184 MHz @ 0.5 uVMOD to off Connect AF VTVM or scope to IC2 Pin 7.
RF Generator to ANT Jack L11, L12 Adjust for maximum audio output.
This has to be a typo as there is no IC2 on this board and isn't even on the list of components.
Is there anyone here a member of cbtricks that can update this to the correct IC #?
Thanks
I guess it helps to look at the schematic, but still wonder why that isn't on the parts list as a IC2 and is it really an IC it kinda doesn't look like one, what does it do, do you know, kinda looks like a distribution point of sorts.
Thanks.
it is the Voltage Controlled Oscillator.
a change in voltage coming in to this oscillator corresponds to a proportional change in frequency at the output.
that is the simple version.
