DX959 Clarifier Won't Unlock
9two7
New Member
Dec 18, 2020
7
3
3
37
Hi all,
I have a Galaxy DX-959 Deluxe edition (the new blue display model) and I'd like to see if anyone was successful in unlocking the clarifier.
I've attempted the modification involving the removal of jumpers JP195, JP196 and the connection of J9 pin F1 to +8V (on J6 in my case) and this resulted in the radio shifting off-frequency with the Clarifier remaining locked for x-mit.
I see that there is an alternate mod which removes R113 and D68 in lieu of cutting the jumpers, but as far as I can see, the removal of the jumpers effectively uncouples R113 and D68, so I'd expect the results to be the same.
Has anyone had any luck unlocking these newer DX-959 models?
I have done numerous clarifier unlocks on the 959's and have not ever used the jumper from J6 ........
It seems you may not have connected the jumper from the +8 volts to the correct J9 F1 pin.
And a frequency alignment is required after this modification using a high quality frequency counter.
Thanks for the reply! I suspect that the 8V which is silk-screened @ J6 is not the 8V source I was supposed to tap into. Looks like the 8V @ J14 is the one which is referenced in the instructions. Will check again and report back
IMHO, a better way is to find a stable constant voltage source that is higher than the stock RX voltage going to the high side of the clarifier. Simply install a 10 turn trimmer pot in series and dial down the voltage until it is "on frequency". No re-alignment necessary. If you can't find a constant voltage source that is higher than the stock RX voltage, you can easily make one. Just mount a LM7809 on the side/back of the radio (heatsink) and a diode and a couple of caps will give you a nice, stable 9v source. Use the 10 turn trimmer to bring the voltage down.
https://circuits-diy.com/9v-power-supply-using-lm7809-voltage-regulator-ic/
This also allows you to "true up" your clarifier if it was off a bit.
FYI - I find that taking 8v off one of the IC's in the radio many times isn't stable enough and can cause a slight shift between RX/TX. Using the LM7809, it is eliminated.
Just my .02
Dr_DX
From Lazarus, CB Tricks era - bless his heart...
This is for a 98VHP - but the CONCEPT is the same,
Break the 8 V PLL RX/TX tie-in R113, and the TX power D68...
Heck yeah, a blast from the past! Does anyone know if he's alive and well? Somewhere I've got a few printed threads from cbt where he helped me iron out some issues back then. Laz and cbt, talk about a throw back.
