Eagle 500
  • Thread starter Thread starter TonyV 225
  • Start date Start date
T
TonyV 225
Guest
What is the input recomendation and what will I exspect on output AM and sideband both. It is reall in excellent shape and is a 1977 model has 7 / 20LF6 tubes I can make offer on it so input would be great it would be a project it needs tubes ..
</p>
I bought one new back then and had it reworked.
It did over 1000 peak on a PDC Meter, I dont know how high it went because meter only went to 1000. It was the best base amp I ever owned. I talked the heck out of it and it held up with no problems. It wasnt hard on the tubes either. I know I was driving it with more than 4 watts. I think it was about 7.
</p>
not cheap........... I called my tube connect. and they said if I got 10 of them, they could do $48.00 a tube, thats just crazzzzzyy..... BOAT ANCHOR time!!!!!!!
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=4cx400000watercooled>4CX400000watercooled</A> at: 1/21/05 7:08 pm
AM, I dont know about the 20lb, and lx6, that you mentioned. However, the 20lf6, is gonna be basically the same tube as a 27lf6, and also, the 6lf6..just different voltages.So, the only somewhat compatible substitute is gonna be the good old, EL509/519. That will still require some extensive work, but, other than spending close to $50 a tube, thats definatly the cheaper way to go....
"NO HEAT LIKE TUBE HEAT"
and its verrrry cold out.........
</p>
Well, $150 aint bad for that amp then, if its in good working condition. Personally, I buy those old amps all the time, just for the fact I like the way they look, and how they sound.Plus, it's more of a nostalgic thing too I guess. Someone gotta keep theese old DAK radios, and sweep tube amps alive!!!!! Just remember, if the tubes go out, you're gonna pay a pretty hefty price to ge them all back in order again!! Even if you get some old tubes, possibly used, or N.O.S, still lookin at another 300-500, to get it back up. Is it worth it to you???
and its snowwwin in the garden......
</p>
