eagle 5000 / galaxy turbo switch to turn off internal amp
With nomad's help I found the issue a smd resistor covered by a bad solder joint on IC5 put in at the factory by mistake and caused the issue.
New look at the output signal after the fix
Oooooh! That was well spotted!! I would have NEVER found that kind of issue... :eek:
So you removed the 22K SMD resistor that was on the back of the board?
Looks indeed very nice and clean now! :) (y)
