I don't agree with everything 'JI' says, but those two links are pretty good. As far as grounding fir safety, do you want to satisfy the 'legal' requirements or really protect your equipment? They are not the same thing at all (legal requirements as in insurance and local ordinances). How well a grouns system works is primarily dependent on the 'dirt' in your area, that's something that also isn't the same everywhere. -Sometimes- depth is a pertinent factor, but most times it isn't. A ground radial has to be deep enough so that you don't trip over it or wind it up in the lawn mower. Unless you happen to live on really dry sandy soil or the desert, you know? In situations like that, you'd be happiest plating the sand with copper (please take pictures??). The idea is to dissipate or transfer energy from what ever you're grounding to someplace other than that 'whatever', at a low resistance. Larger conductors would be nicer at that, but lots of smaller conductors will do the same thing. FWIW, electric fence wire is of adequate size (but more radials are required) and it's fairly cheap, typically sold by the 1/4 mile. It's also usually galvanized and can be a real PITA to solder/bond. How many is 'good'? Probably twice whatever number you think may be adequate, if not more. (This is one instance where more is definitely better! I've never seen any instance where there were too many ground radials.) How long should they be? As long as possible/practical, which has nothing to do with convenience.
Why don't most people use radials instead of ground rods for grounding? Because there's a lot of work involved with radials, more than just pounding a rod or two into the ground.
It really does boil down to Ohm's law...
And the 'catch' in all this is that there are never any guarantees.
