Folks,
I built a couple of 49:1 unun transformers attached to a 130' wire. Amazing of how well this works.
Primary has 2 bifilar turns, and secondary is total of 14 turns.
Some great references out there such as https://elginradio.wordpress.com/2017/10/17/end-fed-half-wave-antennas/
The above picture does not show the 100pF cap across the feedpoint and ground. Having this cap installed does help with the higher frequency bands.
I know its a bad comparison, but testing between my CHA-250B Vertical and this EFHW antenna with an A/B switch - I go from signals that are in the S3 range to S15+. It is an order of magnitude of difference. This is especially the case with 80/40M bands. For 20 and 10, I don't notice as much of a dramatic difference.
Most of the things (box, stainless screws) from Home depot and fairly cheap. The two torroids are mix 43 and are superglued together and then turns of #14 enameled wire. Use at least 2 FT240-43 torroids to improve efficiency. Overall, pretty cheap in cost and great performance.
10 turns of the coax through a mix 31 torroid before feedline goes into the shack to deal with any common mode. Don't put the choke by the transformer as this will impact performance as the coax from Unun to choke is used as a Counter-Poise.
Overall, I think I now have a favorite portable antenna...
If you haven't had an opportunity to build and play with one of these, its not a bad weekend project.
-J
-J
