External S-Meter???
  • Thread starter Thread starter Hook948
  • Start date Start date
H
Hook948
Guest
I'm wanting to replace the small unlighted s-meter on my Harris with a larger/ lighted/external one.Anyone know of a good external S-Meter? Can I just take the two wires off the back of the original meter and run them to the new meter?
Hot Rod Lincoln -Dancing around the World ! ...... CDX948 Central Texas, - Hook948@hotmail.com</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showLocalUserPublicProfile?login=hook948>Hook948</A> at: 9/16/02 12:11:09 pm
Hook,
That's all you may have to do, but maybe not. You
need to find out what 'kind' of meter your 'S' meter
really is. Most meters are the same (either 100 miliamp
full deflection, or something else), but can require
almost anything for full deflection of the needle. If it's
a "standard" meter, then it's a simple remove/replace
thing.
If you can't mount the meter in the same place the old
one was, then make sure that it's in a metal and shielded
enclosure! You wouldn't believe the RFI an unprotected
'S' meter can pick up. You also run into calibrating the
new meter. That can be lots of 'fun' too...
</p>
Reactions: Slowmover
Thanks Doc. No spec.s listed on the meter and checking the service manual only gives me a part #<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":("> . Guess I'll shoot a e-mail to Harris and see. On calibrating the meter, can I use the tone generator thats built into my Motorola R-1034A meter? It will put out 10 diff tones from 304-3200Hz, -40 to +3dbm and a +10db switch,output level @ 600 ohms.
Thanks CG, I'm going to see if I can get one "built in a box"Workman MD-4 maybe? But I'm not ruling out the idea of building one myself.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Hot Rod Lincoln -Dancing around the World ! ...... CDX948 Central Texas, - Hook948@hotmail.com</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showLocalUserPublicProfile?login=hook948>Hook948</A> at: 9/16/02 1:01:57 pm
I did a search for the Yokogawa co.,Got a 800#, Called them and found out it IS a 100 miliamp meter<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> Now I just have to decide on a meter and find out how to calibrate it.I found a post that says:"The correct way to set the "S" meter is to inject 100uV , 0 Modulation and set the meter to "S-9"." What are they talking about??:LOL I've switched back and forth between My FT-840 & FT-990 and get the same readings between the meters,I guess I could just switch between the Yaesu and Harris and adjust the new meter to the same readings on the Yaesu? I know...quick and dirty method but if I dont have the equipment to do it right I guess I can call it close enough<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
Hot Rod Lincoln -Dancing around the World ! ...... CDX948 Central Texas, - Hook948@hotmail.com</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showLocalUserPublicProfile?login=hook948>Hook948</A> at: 9/16/02 1:55:33 pm
Thanks Guys ! I think I'll go with the Workman MD-4. It's cheap ($25), BIG,looks nice,has that "purty" blue lighting(although I may change to green to match the display on radio),and is almost a plug-n-play.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Hot Rod Lincoln -Dancing around the World ! ...... CDX948 Central Texas, - Hook948@hotmail.com</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showLocalUserPublicProfile?login=hook948>Hook948</A> at: 9/17/02 8:14:11 am
Glad to find the WORKMAN MD-4 S-Meter.
CB World Informer Jan 2002 has an article on adding to a radio without an external Jack.
I find an S-meter pretty handy while on the road.
Now if someone still sells them . . . .
LDG Electronics sells an external meter (FT-100) for a pair of Yaesu radios sold with meter jacks already installed.
Only other one I’ve found is:
K-PO S-27 External S-Meter
(With some sellers in the EU).
Plenty of discussions on calibration. W8WWV, in “S-Meter Blues” one of the more comprehensive.
My use is CB. Rolling the highway. Where a glance at the meter provides some context (as in, on one Interstate nearing another and reports of a wreck or similar. But which road?).
So dead-nuts accuracy isn’t the thing so much as relative differences between signals received.
Then, directional problems with antenna. Strong one way, but not some others.
Usually it’s about “loud”. Is that guy really as close as he sounds? Because I can’t hear who he’s replying to.
I’m moving and they are moving. And it’s next to never someone has a rig that’s “unidirectional” unless it’s a pilot car with roof mount.
More like weak & strong flashight beams moving in a faster arc (seconds) as they also arc more slowly following a road course (minutes).
5A6534C5-108C-4375-A0A4-29243CB1BC9D.jpeg 400E7605-A3AE-46A4-BB1F-92BF2CC0A85C.jpeg BEC78812-CDFD-4F43-9B39-C0956026FB90.jpeg
Hook has not been here on the forum for many years.
Had lots of fun talking to him back in the day.
I am trying to remember what kind of radio he threw out of his truck one day......
This is so old it was back in the ezboard days
I know there are a few members here that remember the forum back then.
I know there are a few members here that remember the forum way back then.
It was a Magnum 257 if I remember correctly. LOL
