Faceplate removal
unit_399
EL CAPO Honorary Member Silent Key
I Support WorldwideDX.com!
Jun 17, 2008
2,709
5,106
523
ALEJANDRIA, COLOMBIA SA
I have a cobra 148GTL side mike bezel, and want to remove the faceplate. I want the plate to remain flat and undamaged, so using an Xacto or a razor knife to pop it loose isn't an option. Is there a solvent that I can apply (or soak it in) that won't affect the bezel. I don't care if it removes the paint from the face plate .. Could soaking it in very hot water liquify the glue enough for the plate to come loose easily??
Any suggestions?? Thanks, 73s.
- 399
I put the bezel in very hot water for about 15 minutes, and the plate freed up a bit, but not totally. I applied a little heat with a gun, and the plate came off easily. Thanks MS for your help and 73s.
- 399
