C
Charger383
Guest
Large, easy-to-read meter with 4 scales:
"S" Meter indicates up to 60 dB over S9
Modulation Percentage Scale for use on AM
Power Scale Calibrated for AM and SSB
SWR Scale
Automatic SWR Circuit (no complicated calibration procedure)
"Talkback" Circuit with On/Off Switch and Volume Control
Variable Power Output Control
Roger Beep with On/Off switch and LED Indicator
Galaxy Noise Filter for use on weak signals
High SWR Alert LED Indicator
Galaxy Two Year Warranty
ADDITIONAL FEATURES:
Pre-wired for FC 347 Frequency Counter
+/- 1.0 KHz Receive Clarifier
Noise Blanker and Automatic Noise Limiter
AM, SSB and PA Modes
3-Position Tone Control Switch
Green/Red LED Indicator for RX/TX
LED Channel Indicator
Dimmer Control
Receive Gain Control
Mic Gain Control
DX 949 Specifications:
GENERAL:
Channels
40
Frequency Range
26.965 - 27.405 MHz
Emission
AM/USB/LSB
Frequency Control
Phase-Lock-Loop Synthesizer
Frequency Stability
0.001%
Temperature Range
-30oC to +50oC
Input Voltage
13.8V DC
Antenna Impedance
50 Ohms
Speaker Impedance
8 Ohms
Size
7-7/8"(W) x 9-1/4"(D) x 2-1/8"(H)
Weight
6 lb.
TRANSMITTER:
RF Power Output
AM 4W; USB/LSB 12W PEP
Frequency Response
300 to 2500 Hz
Frequency Tolerance
0.005%
Spurious Emission
Better than -55dB
Unwanted Sideband
Better than -55dB
RECEIVER:
Sensitivity for 10dB S+N/N
AM: 0.5uV; USB/LSB: 0.25uV
Squelch Sensitivity
Less than 0.5uV
Audio Power Output
2W @ 10% distortion
Image Rejection Ratio
-65dB
AGC Figure of Merit
100mV for 10dB Change in Audio Output
Clarifier Range
+1.0 KHz
