Features Pros & Cons,,,Galaxy DX 2527 Base
  • Thread starter Thread starter Charger383
  • Start date Start date
C
Charger383
Guest
Please reply your thoughts here
</p>Edited by: <A HREF=http://pub86.ezboard.com/ucharger383.showPublicProfile?language=EN>Charger383</A>  <IMG SRC=http://www.chargerscastle.com/cbclub/electro.gif BORDER=0> at: 8/6/01 11:17:37 am
Liquid Crystal Frequency Display
Two large, easy-to-read Meters
Meter Scales for Signal, Power Output, SWR and Modulation (AM only)
Red/Green Transmit/Receive LED
"On-Demand" switchable Talk Back Circuit with Volume Control
Noise Blanker/Automatic Noise Limiter
Roger Beep
Mic Gain
Receive Gain
SSB in addition to AM/FM/CW/PA
PA includes Echo, Voice-Changer and 4-position Robot
25 watts Maximum Output Power - SSB
10 watts Maximum Output Power - AM
Variable Output Power
Split Frequency Capability for Repeater Use
1.5 KHz Clarifier for Receive only
Dimensions:
19"W x 6-1/2"H x 14"D (with handles)
16-1/2"W x 6-1/2"H x 13-1/4"D (handles removed)
Weight -- 21 pounds (Shipping weight -- 29 pounds)
TWO YEAR Limited Parts and Labor Warranty
</p>Edited by: <A HREF=http://pub86.ezboard.com/ucharger383.showPublicProfile?language=EN>Charger383</A>  <IMG SRC=http://www.chargerscastle.com/cbclub/electro.gif BORDER=0> at: 8/6/01 11:18:09 am
Re: Feayures Pros & Cons,,,Galaxy DX 2527 Base
all i can say about mine is that i love it!!!!!!!! works great on ssb. and a ton of features...
DIRT NAP GUY.............
</p>
I have one on the way, but I was told that i would need a power suppily to run it. Is this true? I have a 3amp power suppily, will this be big enough? The radio is an EEI turbo tune.
RCI 6900FTB
X-Force 400HD
Wilson Silverloads
RK 56
878 around DX land
2DK57
</p>
RANGE RIDER ALL YOU HAVE TO DO IS PLUG IT INTO THE WALL AND IT IS OFF TO THE RACES!!!!!!!!! YOU DO NOT NEED A POWER SUPPLY TO RUN THIS RADIO..........
BOBBY
</p>
Love mine .only cons I have is talkback is all up in yuor face no adjustment like it's soppose to wonder if thats fixable? like the meters just wish they were white like the dx99 that would be cool
</p>
silverbullet you are right that talk back is very loud!!!!!!
</p>
Beautiful radio------No complaints really.I talk AM mostly and although I have the means to flip a switch, I'm able to get back 75% of the time(and this with the stock mike)without it. Planning on getting a Turner+3 next week.This bad boy is complimented by an I-max2000 and Maco 3 element beams.
</p>
I've had my DX2527 for over a year now and I still love it. Never had any problems with it at all. Attached to my ABS1600 ontop of a 70' tree it talks all over the world.
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showLocalUserPublicProfile?login=kosh>Kosh</A> at: 3/4/02 12:42:35 pm
Why does the Galaxy 2527& 2517 look exactly like the Texas Ranger 696F-SSB? Do they get the boxes from the same company, or are the "guts" similar?
</p>
range rider,you have one on the way from EEI,all i can say is
good luck,also you should have checked into that TT mod,before you flushed your hard earned bucks.ofcourse this
is just my opinions.but have heard reputable techs say that it
doe's not do all that the vendor claims,and might even shorten the
life of your radio.
"Lots of folks confuse bad management with destiny."</p>Edited by: <A HREF=http://pub86.ezboard.com/udnk424.showPublicProfile?language=EN>dnk424</A> at: 3/5/02 4:27:43 pm
The 2527 is made by ranger and sold by galaxy. It uses the same board as the old 2950. Since they no longer produce the ept295013z board it uses they have discontinued the 2527 along with all the other ranger radios that use this board. The 2517 is basically a galaxy 88 in base form but uses a newer board. An upgrade of the old one.
</p>
</p>
I didnt realize the 88 uses a ept690010z board?!?!?
    4 DAYS TO HAMVENTION :love: :cool:
  • @ W4KVW:
    Condolences to Lee for the loss of his Mom.
    What's this??
    **NOTICE: K8MMM will be on 50.145** 100w / 2 el Moxon from Hamvention Fri and Sat....
