FG BEST... Cobra 25?
  • Thread starter Thread starter JustinDePolis2
  • Start date Start date
J
JustinDePolis2
Guest
The cobra 25 can be done the same way, the 19 cannot.
Click Here To Go To FG Best Communications
</p>
I had a similar problem with a Uniden 520 recently. I took it to Justin to look at (I had gotten it used) to see if he could figure out why it would squeal with the KL-200p on. The problem was in the way the bonehead tech who worked on it originally had lowered the carrier for use with the amp. The mods were causing self oscillation on certain channels, which exhibits itself as squealing. He fixed it up and after a few minutes of repairing the junk mods, it worked great! Maybe the 510's you had were set up with the same type of problem?
</p>
