v-quad =11 DB gain
Over a screen door on a submarine?
The 2 Element Quad has at best, roughly 6 dB forward Gain ...compared to a 1/2 wave Dipole at same height.
Delta-Loop is a Quad...
If trying to use Dual-polarity Less Gain will be achieved...
As Henry stated.
The 2 element Quad design has about the same gain as a 3 element Yagi at same height. Here comes the fireworks!!!!
"My V-quad is 5 S units better than my 5/8th's vertical!"
Greg if you're looking for a good DX antenna to start, my HO a 4 element
Horizontal Yagi is a fine choice. They can be mounted below an existing Vertical and preform very well.
I also
Love the LFA style antennas (Loop fed antenna) ...
I have a 5 element on short 14 ft boom (again 6 m) ...works very well...not as well as the long boom 6, but is very quiet on RX
Forgive my laughter on gain, but here is why I chuckle.
I have a
6 Element Wide Space Yagi on a 25 ft boom for 6 meters...True max gain approx.10 dB over a dipole at same height. This is a very old design, tested on a true antenna range from early 60's. So, before the Flame-throwers start, and I burst into flames. I stand-by the info I learned from Bill Orr and others on antennas from old school designs and info
before computer modeling.
All the Best
Gary/W9FNB
PS: Again, MHO stay away from Yagi designs using a Gamma-Match feed system, they normally have slightly less gain, than a dipole fed type design. This is due to the " forward pattern" that these designs can create. This type of feed system can warp the forward lobe on some occasions and generate nulls on the forward pattern.
OK DB/Henry/Others ...flame suit ready!
