Jerry,
Well, it depends on what you are looking for really. If it's primarily a small beam, then the A3s. If it's from one end of the spectrum to the other, then the T-6 (that one end of the spectrum to the other thingy is an exaggeration). Between the two, the A3S would have more gain on the covered bands. BUt it doesn't cover all the bands (no WARCs).
Having said that, I've had an A3. Not as high as it should have been, and didn't really cover the frequencies I wanted at the time. It did work, just not as well as it could have, sort of. It eventually came down and I haven't been all that interested in getting another beam. Different interests. Oh well.
One major factor you might want to check into before plunking down a bunch of money, is all the other thingys you'll need for a beam. That includes a rotor, tower, guys, and all that stuff. If you've already got them, or thought about them, good enough. The @#$ beam will be the cheapest single part of the whole mess! Sort of.
