fixer upper pile, all working 200$ plus shippng obo
Tony
134
2
Got a bunch of stuff here that some one can make use of im tried of looking at it and am never gonna do anything with it.
3 cobra 25s
1 25gtl needs a meter ,1 25ltd classic philly needs a meter, 1 25ltd classic china needs a speaker ,
1 commander 150 amp that all works but for some reason its pulling amps when its not keyed up and the rf light is on.
1( original ) rk 56 says turner by telex on the back,
1 ranger noise cancelling mic , both work fine.
1 small power supply that works but need a 200 ohm vr put back in it some one drilled a hole in the side to make the vr assessable from out side and hit it i guess and knocked the top off of it.
1 cobra 29 that works good looks ruff needs the ch led replaced , its got var,dk. swing, rec boost ( like a pre amp) on the ch 9 , talkback and its got a mosfet final.
1 astatic 600 meter that works fine, one of the corners has a piece missing but dose not hurt the operation .
1 small 100 watt dummy load .
1 meter that can be put in one of the 25s but its a meter out of a 148 i think so its got the swr part in it.
pics in the link.
Fixer Uppers Photos by tmcadams1218 | Photobucket
