One of my locals just swapped his penetrator P500 for a new max 2000 due to the winds we have had recently,
first time around he bolted the IMAX straight to his mast bolted to his house outside the shack window,
ground rod in yard connected to mast & taped his coax to the mast ,
He had rfi issues flattening his cctv cameras & bad RF feedback/buzzing on his audio as he wound it up towards 300w FM ,
clearly there was something different about the IMAX that created havoc with rfi at way below what he could run with the p500 all else been equal,
He took little convincing of what his problem likely was & how we fixed my other buddies unusable IMAX install,
off he went to knights for a radial kit, bought a Trenching spade for the fiberglass handle & we wound a 5 turn 4-1/4" choke from g3txq's chart on his rg213 tie wrapped around the isolator/handle,
His signal went up 1/2 s-unit to me & he can run 1200w FM with no cctv issues or hint of rfi/buzzing in his audio,
ACOM amplifier says reflected power/vswr went down a little too .
