FS: RCI 63FFC4
blasphemy000
Mar 31, 2017
114
202
53
39
Up for sale is my RCI 63FFC4. This radio does NOT have real Toshiba transistors in it. It has the factory transistors that came with the tops blacked out with sharpie. I originally bought this radio as used in early 2018, but it was in factory condition when I received it. I did the frequency conversion myself, put the oscillators on frequency (they were off a couple hundred Hz), and set the bias for the driver and finals in the radio. The maximum power is turned down to around 70-75W carrier and 280-300W PEP with a 4:1 modulation ratio because the power supply that I had wasn't quite large enough to handle this thing at full power. Besides the frequency conversion and reduced power there are no other modifications to this radio. The power can be easily turned back up by adjusting the appropriate VR. Also included is a 9-foot 4Ga power cable. The wires inside PP50 connector are crimped, soldered, and heat shrunk. The fuse holder has a 60A fuse inside. I do not have the stock mic though, it wasn't with the radio when I bought it. It's been setting on my shelf, just looking pretty, for over 3 years now. It should be lighting up the airwaves.
Pictures are included below.
Asking $500 shipped within the lower 48 states with insurance. I accept Pay-Pal for goods/services.
- Brad (KC3MOP)
PowerCable.jpg AntConnector.jpg BoxFront.jpg MountingBracket.jpg RadioBottom.jpg RadioFrontOff.jpg RadioFrontOn.jpg RadioRear.jpg RadioSideMic.jpg RadioTop.jpg
  • @ COWBOYS:
  • @ COWBOYS:
  • @ AudioShockwav:
  • @ iw7ed:
    hello
