I'd like to feel good about my order, anything I should be aware of?
If I should feel bad, I'd like to know it too.
Thanks in advance.
Thanks in advance.
You will need to use a external mic. The one in the radio has a plastic cover for water proofing. And it sounds really bad.
About 6 hours, and the charger doesn't tell you when they are charged which is a bit of a pain.
I usually check the voltage on the display after they've been charging for the 6 hours, if it says 8.2/8.3 volts, then they're good to go.
One battery will last me the full day out on the mountains....Usually take about 60 contacts across a few summits, which may not seem many, but I'm not a '5 x 9' type operator!....Most of the folk I speak to are regular 'chasers' so I tend to waffle on a bit.
The battery life on the 270 is impressive, the radio just seems to 'sip' at it!
ATB, Neil.
