A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
I have to say thank you also for sticking with me, I like to work on radios just hate asking for help.. this repair is probably a little over my head but I’m Sure going to give it my all
I got the radio with no finals they were in a bag so this is maybe a possibility I see the extra pad with the no banded side of the diode going to the pad that runs to the biasing vr
Not here to pick apart your work, just trying to help - I have a question or two...
Note Circled areas, Blue ??? and Yellow Arrow...
Ok, the "bias diode" solders across BASE foil pad right next to the "amber" to ground (Banded end would be oriented towards bottom of photo)
A jumper goes from Bias "Amber" pad to BASE for BIAS - but 22 ohm resistor is on the AMBER pad side soldered across to ground on it's other lead.
So, I see ...
Coloring Legend BLUE = BASE CYAN = Collector GREEN = Foil and Emitter AMBER = BASE BIAS NETWORK Light BLUE = AM Regulator ORANGE = 8 VOLT TX
I just see some stuff not sure if they are "oils" from flux or are they soldering issues...?
Hope the above side to side helps you...
Where your "tip" is, is an RF bypass cap - so to see 6.9K is about normal - the thing keeps RF to where is needs to belong - and DC ground and any voltages OFF of the back panel
