Trying to set the Driver and Finals Bias on my 88HL, no npc on this one.
Following This Page.
I pulled the mirror board (jumper board) Attatched my d.m.m. inline between TP9 and TP8, Key TX adjust for 50-75mA. When i adjust vr10 the meter reads open circuit untill I adjust some more and finally I get a reading only I can set the bias between 0 mA and 40mA if I try to bring it up to at least 50mA the meter reads open circuit again.
When I set the bias for the finals I don't have this issue, one thing I did notice is that for any transistor while setting the bias my reading will steadily decrease the longer i key the DUT, example I start @ 40mA and the longer it's keyed up the number slowly starts to drop and will not hold steady, I don't see why the device draws less current the longer it's keyed up, I was expecting the opposite maybe it's just where i'm at in the circuit..
Any advice would be greatly appreciated, I would like to be able to set the driver bias high enough to meet FSM specs. I'm not sure what to look for (i.e. bad cap/burnt resistor/failing transistor).
Thanks
-Leap
Thanks
-Leap
