Galaxy 95T2 switchable power
I had a RCI 2970 years ago when the green faces first came out. I was told a resounding NO back then. Just know that this is a slightly different design and I am sure u am dealing with a better set of minds than before.
i modded a 95 t one time with a switch to turn on and off the linear section ...
check out the schematic ,,, there is a plug that has a brown and red wire..
can't remember the plug n# on amp bd section.. break the red wire and put a switch ...
before doing so unplug the wire and see if it works first ,, if so go ahead and put a switch ... but remember you will not get much power ,,, the radio is tuned to the linear ... my opion it's not worth doing ..
WOW:oops:
Ive done this with RCI 2970 and Galaxy Saturn Turbo base radio with cutting a brown wire inside that ran to a jumper plug and andi added a switch inline.
