My 959's meter light and frequency counter display stopped working. The problem started a few short weeks prior to this. Each time they would wink out I would cycle the dimmer on/off switch which caused them to come back on. The problem got more frequent until now they won't come on at all. The channel display works perfectly with the switch. The only light mod is I had DTB install a red LED behind the meter which lights up when I key down. The LED used to faintly glow when the meter and freq counter would be on but doesn't now. Any suggestions?
P.S. when I plugged the Viagra board back up and re-loomed the wires I noticed that when I would wiggle the harness the meter light would go off briefly. Looks like I need to pull the covers and start wiggling wires.
