Hello all,
It seems lately I get nothing but strange cases and I can't catch a break with a routine alignment.
This time around I have a Galaxy DX2517 base station. Problem with this one is that for some reason the 10.240Mhz oscillator is off frequency by about 1khz. Basically when I go to probe Pin 4 of IC3 I get about 10.2405Mhz. Service manual says to allow only about 200hz of tolerance tops. I tried swapping the crystal only to find that when I do that, the issue gets worse and I'm off by about 1khz or more vs the 500hz I have now. When I probe the crystals directly I find that they are oscillating within tolerance or close to it but the actual output from Pin 4 comes out altered. Furthermore when I put back the previous crystal I find that someone must have previously tried to deal with this issue too as this crystal is about 500hz too low. Basically the MC145106P seems to add an extra 1khz to the signal and the previous person trying to resolve the issue put in a crystal that is 500hz too low to try and get as close to the right frequency as posible and this way we are only high by about 500hz vs the full 1khz we get if we put a within tolerance crystal.
Anyone have any idea what this may be besides the actual IC? Don't have a replacement so I might have to resort to some kind of hacked repair. Unfortunately there also seems to be no voltage chart for this radio or an actual full service manual. The info I'm getting is posted on Cbtricks.
