Galaxy dx2547 (959) No squelch
CbRadiosPRONTO
Well-Known Member
I Support WorldwideDX.com!
Mar 21, 2014
432
166
USA
www.cradiospronto.com
cannot engage squelch (constant static). Squelch pot is adjusting correctly 0-50k. The problem is on both AM and SSB, however I check Vr3/d15 and vr4/d35 anyway, and they're good.
Should I be looking at IC1 or possibly a transistor? I don't have a voltage chart.
Suggestions?
Thanks, Robb. I traced it back to Q44. The trace was pulled away from the board, slightly. Re flowing the solder did not fix it though. Q44 was actually bad. It must have gone bad from having the bad connection.
She's back in business.
PS: This is a fresh out of theIMG_0180.JPG box radio. Arg. Happens too often.
Reactions: Robb
