Galaxy DX2547
Jackeeson
New Member
Oct 22, 2019
9
3
3
This is an update on the Galaxy DX 2547 meter light problem. If interested, you can read the thread here: Link. It had the title of “Hello” so I’m posting the update here under Galaxy for more relevance.
The meter light problem was solved by replacing the LED pcb board with yet another board—the original! You may recall from the thread that since the light “wasn’t working” (the actual lamp tested out okay), and after some testing, I decided to just replace the $50 LED pcb board rather than remove & test all the transistors, etc. I received a “new” board from a popular company that I sometimes order parts--but probably will no longer.
This particular radio powers on with a push button and to turn on the lights, you must activate a separate switch, if the light was off. I didn’t use this radio for a few years, as I have others with different controls/switches.
The main point: there was nothing wrong with the original board, I just forgot to turn on the dimmer switch that activates the lamp! The new “replacement” board was a dud! That’s when the light actually would no longer work. I can now join the Dumba$$ Club.
I didn’t find this out until I decided to exchange the board with the original (after becoming totally disgusted testing everything in the circuit and then some). Guess what? The light worked fine. The replacement board the XXX company sent me was a dud, but I had it a while before I installed it, thus no returns…or did someone else “return” it, and was it “inadvertently” (or not) sent to me?
Later, after examining the “new” board, I discovered that some of the terminals were also reversed! Even after I corrected the terminals, the board still failed to work. Then I remembered reading about some companies buying parts from some countries that were clones/knock-offs/not to spec parts. Supposedly more prevalent with radio parts (some proprietary) that are no longer used in newer models or have been discontinued/unavailable.
Moral of the story: don’t screw-up like I did and forget to turn on the switch; don’t jump the gun and replace parts without thoroughly/systematically testing; and be careful where you order your replacement parts. In defense of the company, when selling thousands of parts, a few duds no doubt exist as well as unscrupulous people returning damaged parts. Lessons learned.
I did replace the original bulb with a nice bright LED!
Reactions: TM86
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
