There are several variants of the same thing - adjusting Gate voltage to make the Radio key up right...
VR 10 - FINAL
VR 12 - Driver
There are points you can check VOLTAGES on, that help you - and there are two spots to check and use the one that works for you - but either way, DO NOT SET BIAS ABOVE 3.3V - these will LATCH ON and blow up if you go too high...
L33 and L37 - I highly recommend that you use - REORIENT - L37 and L33 opposite of what is shown - for you can then set your TEST LEAD POSITIVE (+) to the top lead of the resistor if you need to verify gate or tap for RF signal thru Scope Probe - to see RF or Voltage.
The ZENER 7.5V recommendation is arbitrary - buy you may need to swap that 5.6 or even 5.1V Zener to a higher voltage to obtain any gain or if you wish to have swing. The 5.6 or 5.1V Zeners used may limit your ability to obtain the Drive peak you want.
VR 10 - FINAL
VR 12 - Driver
- The FOREMENTIONED is what will happen if you set VR12 or VR10 too high - EACH MOSFET IS DIFFERENT - EVEN IN SAME BATCH - SO USE TP "TAB" for mA ON SEPARATE METER TO CHECK CURRENT DRAW AS YOU SET VOLTAGE! VOLTAGES ARE CHECKED TO FOIL GROUND NOT CASE GROUND!
- AMMETER = CURRENT DRAW - TP 7 to +POSITIVE of AMMETER and -NEGATIVE to TP you wish to check - and NO MORE THAN 35mA until you are comfortable with results.
- DONE ON TX INTO DUMMY LOAD TP 7, 8, 9 JUMPER BOARD REMOVED WITH AMMETER INSTALLED - READ ABOVE
- One - Use TOP LEAD OF L33 or L37.
- Two - Check Voltage on BANDED leg of D90 or D92
