My apologies, I grabbed the wrong one initially.This is NOT an o2a radio.
Okay yours is the Matsushita M58472P. LD is pin 7... same song.
Pin 7 will be high when locked, Low when not.
And this radio does kill BOTH RCV and TX when it is not locked.
Hmm. Sams CB-155 has the "B" version.
Question was about the "A" radio. Totally different design, different vendor, different PLL chip.
Gonna see if I have Sams CB-147 in the basement. Would help.I
IMO There is a list of things that need to be done first to that radio. The corrosive glue needs to be removed. All the electrolytic caps need to be changed. Besides a thorough visual inspection, the glue and caps should all be taken care of before the power is employed. A new power plug and a standard 4 pin mic jack would also be on that list. It’s a good restoration project for somebody like me, mainly because I have a lot of the spare parts, plus I enjoy restoring them, but I’m sure most people wouldn’t care to spend the time or money to do the job correctly.
If they're not badly rusted, I still grab them up for $5 or less at garage saltooes .
I
So what's the verdict? Any positive change?Well ok, I already replaced them with electrolytic.
Agreed..I replace them with an electrolytic only as a temporary solution, usually when I don’t have an exact replacement in stock. For the time being I wouldn’t worry too much about the stability of an AM only radio. It’s not SSB where drift needs to be kept to a minimum.I have heard people say yes you can, and I have heard people say you shouldn't because the tantalums are felt to be more "temperature stable" and "accurate". Since this is in the PLL I would personally be inclined to stick with tantalums if at all possible.
I would welcome others to chime in with their thoughts....
