GE Superbase common bugs.
jetman
Feb 6, 2013
47
4
18
Hello,
I was able to locate a Superbase on eBay that was for parts. Hooked it up and got a popping crackly every time I played with the volume. Cleaned that VR. Then seemed to be ok. Did the initial alignment of her and now she's tx'ing poor and I lost a lot of receive sensitivity. BN and ANL really chop out a lot of signal that I want to come in. It's also hit or miss on average RX strength also.
Are there any known bugs is this radio? Other than the split pc boards being a pain in the @$$!
Clean ALL switches and pots. Pay particular attention to the A/B antenna switch.
Check dual board interconnectors (white plugs) but be careful with them.
Cold solder joints is always a thing to check for - even if they just look iffy. Hit all the solder joints if you have the time.
I don't like old electrolytic caps either. Some old and not-so-old radios may need them checked and replaced; been my experience . . .
