GRE PSR-300 Item number: 140634183646
n4jzy
Jan 22, 2011
12
2
13
This scanner probably has about 5 hrs of use on it. Looks as new. Purchased a Base Scanner so the portable is excess to my needs. As with all used electronic items this unit does not come with a warranty but will not be doa.
Thanks for Looking!
Features
- Triple Trunking Handheld Scanner
- Motorola Analog, EDACS, LTR
- 1,000 CH / 1,500 TGID
- CTCSS / DCS
- 20dB attenuator
- SAME (FIPS) / Weather alert
- Skywarn
- Spectrum Sweeper
- 4x16 Alphanumeric Display
- Signal strength meter
- Backlit Keypad and Display
- PC Programmable
- Field Upgradeable Firmware
- And MORE!
1. Frequency range:
VHF Low 25.00000 - 54.00000 MHz.
VHF Aircraft 108.00000 - 136.99166 MHz
VHF High 137.00000 - 174.00000 MHz
216.00250 - 299.93750 MHz
UHF Low/T 300.00000 - 512.00000 MHz
UHF High 764.00000 - 960.00000 MHz
1240.00000 - 1300.0000 MHz
Except cellular band: 824 - 848.9875 MHz and 869 - 893.9875 MHz
Step: 3.125, 5, 6.25, 7.5, 8.33, 10, 12.5, 25 kHz
2. New 700MHz coverage and Upgradeable CPU firmware for future rebanding
3. 10 bank and 1000 channel memories for trunking bank and channel combined with conventional mode memory
4. Multi trunking of Motorola (type I, II and hybrid analog system), EDACS wide and LTR
5. CTCSS and DCS Sub-audible encoded squelch mode.
6. Scan both trunking channels and conventional channels at same time.
7. 1500 ID memory in 10 ID banks, 5 sub-ID memories in each bank, and each sub-ID memory has 30 ID locations.
8. Alphanumeric data entry.
9. PC programmable and unit-to-unit cloning.
10. Spectrum sweeper function.
11. Pre-programmed Marine, CB, FRS/GRMS/MURS, Public safety, Aircraft, Amateur (Ham), Railroad, and Weather frequencies.
12. WX alert and SAME receiving with 10 FIPS area code memories.
13. Skywarn function.
14. Attenuator control. (Normal attenuator and Global attenuator)
15. Built-in power save circuit.
16. Frequency tune mode. (Frequency UP or DOWN)
17. “Zeromatic” tuning system.
18. Change the direction at the searching by UP or DOWN.
19. 60 channels/sec. scanning rate and 75 steps/sec. searching rate.
20. 2 second scan and search delay.
21. Manual selection for channel.
22. Scan mode. [Cleared channels (000.000 freq.) are not scan.]
23. Deleting a frequency from a channel.
24. 1 limit search bank.
25. Key lock for safety.
26. Key tone and alert tone.
27. 16 characters x 4 lines and 8 icons LCD.
28. Signal strength meter.
29. Backlit LCD and key pads.
30. Low battery indicator by LCD.
31. Crystal filter for 2nd IF and Ceramic filter for 3rd IF section.
32. 50 lock out frequencies per search bank, Public safety, Aircraft, Ham, Railroad, Limit search. (Totaling 250 frequencies)
33. Frequency lock-out review and Channel lock-out review.
34. BNC type antenna connector.
35. Earphone jack. (D = 3.5 mm stereo)
36. External power / charge jack.
37. PC Interface / Clone jack.
(D = 3.5 mm stereo, and use GRE USB cable No. 30-3290)
38. Operating voltage: DC 6 Volts “AA” cell x 4 pcs.
39. Ext. power and charge voltage: DC 9 Volts (regulated)
40. Dimension: Approx. 65 (W) x 42 (D) x 145 (H) mm
41. Weight: Approx. 240 g without antenna and batteries
42. Accessory: Rubber antenna, Owner’s manual, Normal Battery holder,
Re-charge Battery holder and Belt clip.
