Alright a guy I know gave me a Cobra 25 LTD Classic and a Palomer 225 Linear, The radio is in mint condition and the Linear is a bit beat up but works, so my problem is now I have tested both boxes and they work just great, if you are familiar with this amp you'll know it has a Pre-amp aswell and auto SSB Switching, but the power leads are too short to work with and the wires are a bit worn out and brittle, so I am going to solder in some new power leads, I tried connecting this amp and a JCPenny 6247/SSB radio up to it with a "Calrad" adjustable power supply set to 12Volts (Goes up to 15Volts) but when I key up the power meter drops to 10Volts, any ideas? What about if I use only the amp on the power supply instead of both the amp and the radio?
Also what radio wold be better to use this with? The Cobra 25LTD classic , the Cobra 89XLR Base , or the JCPenny 6247/SSB.
Note the JCPenny is the only one with SSB.
I was also thinking about using it with my base station which is a Cobra 89XLR (Made in 1977)
Thanks.
73's...
Thanks.
73's...
