Ground plane Question
Se7en
Jun 27, 2010
4,573
224
Ca
IV been using a Tram 1465 kit on a 10' pole using a Diamond CR320A it work's OK.
What is the 4x 18" ground rods on the mounting kit for? I thought it was a Ground plane in-case you cant ground your mast....?
A ground plane is completely different than a grounded mast. A ground plane functions as part of the antenna and the signal emitted from the antenna basically reflects off the ground plane. A ground plane may or may not be connected to electrical ground. A grounded mast is exactly that and is connected to electrical ground. Mounting a vertical antenna without a ground plane on a grounded mast is the same thing as mounting it on an ungrounded mast.
Thanks didn't know that
