Ground Planes
4600turbo
151
I just got a old ground plane kit for HF vertical antenna and the radials are very old, and sun beaten. I was wondering if I could replace the radials with francis 5' antennas or larger. Are these radial just antennas? They look just like Francis antennas.
If they're not Francis's then can I panit them?
Those radials are just conductors of the proper length for the frequency of the antenna. They can be made from almost anything conductive. If you have a few Francis antennas and want to use them, have at it. Common aluminum tubing would work just as well.
Painting. If the paint isn't conductive it shouldn't make any difference at all.
(Hot Pink works exceptionally well, I think!)
Should have added this, just forgot, sorry 'bout that.
You will probably have to do some 'tunning' of those Francis whip radials. No idea how difficult that would be. It will probably make them unusable for antennas without reversing that 'tunning' thingy. If they are 'trash' to start with you haven't lost anything. If they are still usable, I'm not too sure I'd do it. Up to you...
Francis antennas are 1/4 wave. and the a99 is 1/2 wave. Will that pose a problem? It's going to be used on 10m and 11m.
Also will length of the antennas or radials being used make a difference?
