Grounding for Tuner and Rig
VU3PYG
Mar 8, 2009
7
49
Hello Friends,
I have a query regarding grounding. It is required to ground the rig and tuner. Can i make it common?
Thanks,
VU3PYG
I do. All my equipment is grounded. Run all your ground wires to a ground bus, then one large gauge cable to your ground rod.
Bus bar
Bus bar
I think we may be running into a little language/terminology misunderstanding here. If by 'common' you mean the 'third' wire electrical ground in house wiring, that isn't such a good idea. It may introduce unwanted radiation/interference into the electrical wiring. It also presents some safety risks.
If 'common' means 'earthing', or 'grounding' to a common ground system, such as telephone services use, then yes, it can be beneficial, such as for lightning safety. It depends to a great extent on what type of antenna you may be using. If it's a 'balanced' antenna, no RF ground is typically necessary. If it's an 'unbalanced' antenna such as a random length wire, then a very good RF ground system is definitely a necessity.
All of this is probably unnecessary, but i have no idea how electrical things are termed in India. Hope I didn't make it unnecessarily complicated, or confusing.
Thank you for the replies.
The earthing i am about to use is a one which is specially made for only hamradio purposes and not for any other device. In this regard by mentioning common i meant whether i can use the same earth for both rig and antenna tuner together, like tying both of them together. Is this fine?
Simple Reply is, YES
Regards,
John-KD5WJY
Yes, you should have only one common ground for all your radio equipment. You should use a separate ground wire from each piece of gear to the common ground point. Do NOT connect each piece together and then run just one wire to the ground point.
